Displays shared-port information from neighboring shared links for one or more EAPS domains.
| port | Specifies a shared-port. |
| detail | Specifies to display the status of all segments and VLANs. |
N/A.
If you enter the command without the detail keyword, the command displays a summary of status information for all configured EAPS shared ports from neighboring shared links. If you specify an EAPS shared-port, the command displays information about that specific port. Otherwise, the command displays information about all of the shared-ports configured on the switch.
You can use the detail keyword to display more detailed status information about the segments and VLANs associated with each shared port. For full details of the significant fields and values in the display output of the command, see the relevant tables in the show eaps shared port {port} {detail} command description.
